C3 Vette Registry - The Best Resource on the Net for C3 Vettes! C3 Vette
C3VR Forums Thread
Not Logged In! Login or Register!  Users Online: 11 / Help
Features  Find C3 Parts on ebay in only 2 or 3 clicks!
Supporting Vendors
Corvette America
Mid America Motorworks
Rik's Corvette Parts
Bair's Corvettes
VetteBookStore.com
CorvetteClothing.com
Volunteer Vette Products
Corvette Specialties
Car Transport
C3 of the Month
None Current
Enter Yours Today!
Vanity Plates
7D7
madjaxs
Online C3 Show
13
C3s are Registered
Buy Now
Corvette 50th Anniversary
Kindle
Kindle
Corvette
Corvette
Collector's Originality Guide Corvette 1968-1982 (Paperback)
  FAQ FAQ  Forum Search   Calendar   Register Register  Login Login
Shifter problem-Need ideas -UPDATE
 Post Reply Post Reply
Author
ranger3 View Drop Down
Lifetime Member
Lifetime Member
Vette(s):
1975 L48 AT AC T-top
Post Options Post Options   Quote ranger3 Quote  Post ReplyReply Direct Link To This Post Topic: Shifter problem-Need ideas -UPDATE
    Posted: January 31 2010 at 2:48pm
Hey Guys,
I took the 75, all stock automatic, out for a drive today.  I went for about 25 miles and came home. The only thing I noticed while driving was that when I came to a stop and idled, the car seemed to shaking a bit, like a loping cam. The car shifts fine through the gears.
When I got in the driveway and shifted into Park, the shifter felt like it took much less effort, than normal, to move through the different gears. Once in park, the key would not move past the first detent. By this, I mean turning off from the running position. It will not go into the lock or accessory positions. I can pull the key out, even though the ignition is not in the locked position. I tried several different keys, with the same result.
I then cranked the car again and put the car in drive, then reverse, then back to park. The transmission is in the gear the shifter is aligned with in the shift indicator. Also when placing the transmission in gear, the shifter doesn't feel like it has a much resistance as before.
The ignition/key situation seems to be related to the shifter problem. I need some ideas on where to start looking. Could it be a broken transmission mount or motor mount? If so, is this causing some kind of problem with the shifter. To the best of my knowledge, the transmission has never been out of this car. Help!
Thanks,
Scott
Edited by ranger3 - February 06 2010 at 10:27am
C3VR Lifetime Member #114
Back to Top
bio11 View Drop Down
Standard Member
Standard Member
Vette(s):
1972 LS5 Convertible,Auto.Targa Blue with Black Interior.
Post Options Post Options   Quote bio11 Quote  Post ReplyReply Direct Link To This Post Posted: January 31 2010 at 3:35pm
It sounds like it may be the cable that runs from the side of the transmission up to the steering column. Since you said it shifts easier I'm wondering if the cable has broke or came off at the column or down on the side of the transmission. It's held on by a cotter key on each end.
Lonnie
Back to Top
Lifetime Member
Lifetime Member
Vette(s):
Post Options Post Options   Quote ranger3 Quote  Post ReplyReply Direct Link To This Post Posted: January 31 2010 at 3:48pm
Thanks Lonnie, that's a great idea. I need to get the car in the air to take a look. I've had no previous problems with the car and this just started today. Thanks for the clue.
Scott
Back to Top
Adams' Apple View Drop Down
Lifetime Member
Moderator
Lifetime Member (Moderator)
Vette(s):
#1-1974 L-48 4spd Cp Med Red Metallic/Black deluxe int w/AC/tilt/tele./p/w-p/b/ Am-Fm/map light Multiple NCRS "Top Flight" #2-1985 Bright Red/Carmine Cp.L-98/auto Member: NCRS, NCRS Texas, Corvette Legends of Texas
Post Options Post Options   Quote Adams' Apple Quote  Post ReplyReply Direct Link To This Post Posted: January 31 2010 at 8:33pm
I agree with Lonnie's assessment. This would explain the easier shifter movement, as well as being able to remove the key, without it being in the "Lock" position.
Don't know about the vibrating/loping issue, tho...that could simply be from sitting in storage too long?
Joel Adams
C3VR Lifetime Member #56
(click for Texas-sized view!)
             NCRS
"Money can't buy happiness -- but somehow it's more comforting to cry in a CORVETTE than in a Kia"
Back to Top
Lifetime Member
Lifetime Member
Vette(s):
Post Options Post Options   Quote ranger3 Quote  Post ReplyReply Direct Link To This Post Posted: January 31 2010 at 8:36pm
Thanks Joel. If it is the cable, is that difficult to replace? Also, what's the correct name of the part?
Scott
Edited by ranger3 - January 31 2010 at 8:42pm
Back to Top
Lifetime Member
Moderator
Vette(s):
Post Options Post Options   Quote Adams' Apple Quote  Post ReplyReply Direct Link To This Post Posted: February 01 2010 at 6:21am
Shift column interlock cable...I think that's what it's called...
It's not too hard to change, It simply connects to the shift linkage on the trans at the bottom, and the column at the top. Check to see if it just came loose, as the clips/pins can fall out mysteriously.
Joel Adams
             NCRS
Back to Top
Lifetime Member
Lifetime Member
Vette(s):
Post Options Post Options   Quote ranger3 Quote  Post ReplyReply Direct Link To This Post Posted: February 01 2010 at 8:40am
Thanks Joel and Lonnie. I will take a look at it soon. I really appreciate the information.
Scott
Back to Top
lukesvette View Drop Down
Lifetime Member
Lifetime Member
Vette(s):
1979, Targa Blue (72 Color), Pace Car rear spoiler, L88 hood, Dark blue factory interior, 525HP 406, HD 700R4, 370 gears,Steeroids, composite rear spring, TT IIs wrapped in T/A Radials.
Post Options Post Options   Quote lukesvette Quote  Post ReplyReply Direct Link To This Post Posted: February 01 2010 at 9:04am
Should I have one of those on a 79? I don't think I do!!
Veteran of Operation Iraqi Freedeom
101st Airborne(AirAssault!)
God Bless America
Support Our Troops
Back to Top
Lifetime Member
Moderator
Vette(s):
Post Options Post Options   Quote Adams' Apple Quote  Post ReplyReply Direct Link To This Post Posted: February 01 2010 at 11:12am
Yes....as far as I know, all Sharks had them...with the exception of the '68s with the key in the dash.
There is another thread here with a similar issue, with some pics of the cable under the hood. It was fairly recent.
Edited by Adams' Apple - February 01 2010 at 11:28am
Joel Adams
             NCRS
Back to Top
Lifetime Member
Lifetime Member
Vette(s):
Post Options Post Options   Quote ranger3 Quote  Post ReplyReply Direct Link To This Post Posted: February 06 2010 at 10:33am
First let me say a BIG thank you to Lonnie and Joel. For the benefit of those that may experience a similar problem, the cable was siezed in the outer housing, therefore not moving anything, just curling up on the lower end at the tranny clevis. I removed the cable and soaked it with PB Blaster. It freed up almost immediately. I exercised it for a while until it was as free as a new cable. Reinstalled and everything works like it should. Shifter and ignition lock all operating normally now. Thanks to all. This kind of assistance is what makes this site so great.Clap
Scott
Back to Top
Lifetime Member
Lifetime Member
Vette(s):
Post Options Post Options   Quote ranger3 Quote  Post ReplyReply Direct Link To This Post Posted: February 07 2010 at 7:20am
Scott
Back to Top
Lifetime Member
Lifetime Member
Vette(s):
Post Options Post Options   Quote lukesvette Quote  Post ReplyReply Direct Link To This Post Posted: February 07 2010 at 7:50am
I checked out the other thread - my column does not have the eye on it for the cable to attach to. BUT - I can not pull the key out in any position other than Lock...
God Bless America
Support Our Troops
Back to Top
Lifetime Member
Moderator
Vette(s):
Post Options Post Options   Quote Adams' Apple Quote  Post ReplyReply Direct Link To This Post Posted: February 07 2010 at 9:18am
But...can you move the shifter out of Park with the key in the "Lock" position? That's really the purpose of the system...it's more of an anti-theft deterrent, as well as to keep someone(young-uns) from accidentally knocking the car out of park/reverse.
Being able to remove the key from the cylinder in any position other than "Lock" is strictly a function of the key cylinder. If the key will turn to "Lock", then the key will come out. The problem we see is that sometimes, the shift interlock cable will not allow the sleeve on the column to turn so that the key cylinder can be twisted to the "Lock" position, which makes it hard, if not impossible, to get the key out.
If you remember the older style, column shift automatics, the gear lever was attached to a sleeve/barrel on the column that would turn/move when you moved the shift lever up/down to go into reverse, neutral, drive, etc. On the console shifted automatics, the sleeve is still there, but instead of being attached to a lever, it has a cable that operates it from the trans. When you move the shifter on the console, the sleeve will turn...you can see it move, just like it would with a column shift lever. A lot of times, when the cable is messed up, and you can't get the key out, you can reach up by hand and twist the sleeve on the column, and get the key to turn to "lock", and remove the key.
Hope this makes sense. If I get time today, I'll take a pic or two of the set-up...it might help.
Joel Adams
             NCRS
Back to Top
Lifetime Member
Lifetime Member
Vette(s):
Post Options Post Options   Quote lukesvette Quote  Post ReplyReply Direct Link To This Post Posted: February 07 2010 at 9:22am
Now I unnerstand Joel!! I'll try to take it out of park with the ignition in the lock position and let you know wha hopponWacko
I'm guessin that I'll be able to run all the way through, since mechanically, there's nuffin ta stop it...
God Bless America
Support Our Troops
Back to Top
Lifetime Member
Lifetime Member
Vette(s):
Post Options Post Options   Quote lukesvette Quote  Post ReplyReply Direct Link To This Post Posted: February 07 2010 at 2:51pm
Sher enuff - I can put the car all the way thru da gears while in Lock. I do have the firewall mount, but no attachment eye off of the column....where that part is, I donno...Shocked
Edited by LukesVette - February 07 2010 at 2:52pm
God Bless America
Support Our Troops
Back to Top
Lifetime Member
Moderator
Vette(s):
Post Options Post Options   Quote Adams' Apple Quote  Post ReplyReply Direct Link To This Post Posted: February 07 2010 at 8:44pm
Your car may have been an export car, too.
Joel Adams
             NCRS
Back to Top
Lifetime Member
Lifetime Member
Vette(s):
Post Options Post Options   Quote lukesvette Quote  Post ReplyReply Direct Link To This Post Posted: February 08 2010 at 8:27pm
Checked my very spotty tank sticker - Car was built in St Louis and delivered to White Allen Chevrolet, Dayton Oh. - I don't see an export code listed in the options.
Bubba musta got in dere a while before I got the Lukester...Confused
God Bless America
Support Our Troops
Back to Top
Forum Jump Forum Permissions View Drop Down
Bulletin Board Software by Web Wiz Forums® version 9.68
Copyright ©2001-2010 Web Wiz
This page was generated in 0.984 seconds.
Official C3 Vette Registry Community:
Home | Forums | Email | Who's Online | Clubs | Events | Member Stats
Other Official C3 Vette Registry Areas:
Members | Research | Shop | My Account | About C3VR
Corvette is a registered trademark of the General Motors Corporation(GM) & Chevrolet Motor Division. Vette Registries, LLC is responsible for all site content (except where otherwise noted) and does not claim or imply that Chevrolet or GM is responsible for Official C3 Vette Registry content. Vette Registries, LLC is independent from GM and is not affiliated with, sponsored or supported by GM.  Copyright/trademark/sales mark infringements are not intended, or implied and are in fact used to support GM, Chevrolet and Corvette
Official C3 Vette Registry content is Copyright 2001-2010, Vette Registries, LLC. Content may not be reused without written consent. All Rights Reserved. NS
Corvette (Vette) Model Years on this site: 1968 1969 1970 1971 1972 1973 1974 1975 1976 1977 1978 1979 1980 1981 1982 60
