C3 Vette Registry - The Best Resource on the Net for C3 Vettes! C3 Vette
C3VR Forums Thread
Not Logged In! Login or Register!  Users Online: 17 / Help
Features  Find C3 Parts on ebay in only 2 or 3 clicks!
Supporting Vendors
Rik's Corvette Parts
Mid America Motorworks
Corvette Specialties
Corvette America
Volunteer Vette Products
CorvetteClothing.com
Bair's Corvettes
VetteBookStore.com
Car Transport
C3 of the Month
None Current
Enter Yours Today!
Vanity Plates
SARGE81
Sarge81
Online C3 Show
13
C3s are Registered
Buy Now
Corvette by the Numbers
Corvette 50th Anniversary
Corvette Enthusiast Magazine - $29.97 for 12 issues
Only $29.97 for 12 issues
Corvette and Chevy Magazine - $32.95 for 12 issues
Only $32.95 for 12 issues
  FAQ FAQ  Forum Search   Calendar   Register Register  Login Login
Engine rebuild-crank question
 Post Reply Post Reply
Author
Gribble123 View Drop Down
Lifetime Member
Lifetime Member
Vette(s):
1977 L-82 originally white/buckskin interior. Currently undergoing a frame-off resto. and modifications.YEEHAW!!!
Post Options Post Options   Quote Gribble123 Quote  Post ReplyReply Direct Link To This Post Topic: Engine rebuild-crank question
    Posted: July 29 2010 at 5:08pm
Hi folks. First, I want to apologize for not being on here in a while, that is a subject for another thread. For now, I have a question about my engine build.
I'm rebuilding my 350 block, 2 bolt main. I have a few cranks to choose from, all having the same cast numbers. I understand that the 305 and the 350 cranks have the same numbers, with the main differences being in the balance.
 My question is...How do you tell the difference? Any input would be appreciated.
Thanks, folks.
Alan
Back to Top
Adams' Apple View Drop Down
Lifetime Member
Moderator
Lifetime Member (Moderator)
Vette(s):
#1-1974 L-48 4spd Cp Med Red Metallic/Black deluxe int w/AC/tilt/tele./p/w-p/b/ Am-Fm/map light Multiple NCRS "Top Flight" #2-1985 Bright Red/Carmine Cp.L-98/auto Member: NCRS, NCRS Texas, Corvette Legends of Texas
Post Options Post Options   Quote Adams' Apple Quote  Post ReplyReply Direct Link To This Post Posted: July 30 2010 at 5:16am
Good to see you back, Alan!
I never realized the cranks had the same cast #, but they certainly do. I don't know for certain how to tell which is which, but I would assume if they were side by side, the difference in the crank throws/counterbalance weights would be noticeable. Strange that GM would cast them with the same #.....
Joel Adams
C3VR Lifetime Member #56
(click for Texas-sized view!)
             NCRS
"Money can't buy happiness -- but somehow it's more comforting to cry in a CORVETTE than in a Kia"
Back to Top
cthulhu View Drop Down
Lifetime Member
Lifetime Member
Vette(s):
69 Conv #'s Match 427/390, TKO-600, 3.36 HD Posi, T/T, PS, PB, Leather, Comp Mag 270 & Mag Pro Roller Rockers, Edel Air-Gap RPM, SpeedDemon 750 MS, MSD 6AL+Tach Dist+ Blaster SS+Wires, Holley Blue Fuel Pump, K&N, Jet-Hot Hooker Side-Pipes,Steeroids
Post Options Post Options   Quote cthulhu Quote  Post ReplyReply Direct Link To This Post Posted: July 30 2010 at 7:19am
i would imagine they are the same.  once it has been balanced it will be different.
I would factor in 2 things.  i would look for one that hasnt been balanced and hasnt been turned
since balancing a crank means removing material from the counter weights having more material left to remove is better.  ive seen some cranks that looked like swiss cheese in all the work they tried to get a bad crank to balance.
also..  if you find one that only needs to be turned .010 rather than .040 that is preferable.
Back to Top
nosal1 View Drop Down
Gold Member
Gold Member
Vette(s):
1980 Corvette Torch Red with Gold metallic 370HP/350 CU.IN.Turbo 350 w/shift kit.Originally CA.Car with 305 CU.IN.
Post Options Post Options   Quote nosal1 Quote  Post ReplyReply Direct Link To This Post Posted: July 30 2010 at 8:44am
Good Afternoon Gribble,
           I can possibly help you with the Identification of both 305 and 350 cranks...Firstly the weight of the two are different as the 350 crank is heavier..Another way to ID them is that on the front "throws"lobes, the holes drilled in them are shallow in the 350 and deep holes in the 305,thereby lighter.Hope this helps and if you have any other questions I may be able to help with,please do not hesitate to ask..
     Sal C      nosal1
Back to Top
Lifetime Member
Lifetime Member
Vette(s):
Post Options Post Options   Quote Gribble123 Quote  Post ReplyReply Direct Link To This Post Posted: July 30 2010 at 1:44pm
Thanks Joel, Ben. Good to be back.
Nosal1, thank you for the info. That is more than I found by searching for it. I will see if that helps.
Thanks guys,
Alan
Back to Top
ranger3 View Drop Down
Lifetime Member
Lifetime Member
Vette(s):
1975 L48 AT AC T-top
Post Options Post Options   Quote ranger3 Quote  Post ReplyReply Direct Link To This Post Posted: July 31 2010 at 11:02am
Great question and very informative answers. I learn something everytine I check in. Thanks,
Scott
C3VR Lifetime Member #114
Back to Top
Lifetime Member
Lifetime Member
Vette(s):
Post Options Post Options   Quote Gribble123 Quote  Post ReplyReply Direct Link To This Post Posted: August 08 2010 at 8:52pm
Hey Ranger-how have you been. We're still driving those POS Impalas in our Dept. We even had Chevy Reps. there to address all the issues we're having with the cars...they were no help.
How's that for customer support?
Back to Top
lukesvette View Drop Down
Lifetime Member
Lifetime Member
Vette(s):
1979, Targa Blue (72 Color), Pace Car rear spoiler, L88 hood, Dark blue factory interior, 525HP 406, HD 700R4, 370 gears,Steeroids, composite rear spring, TT IIs wrapped in T/A Radials.
Post Options Post Options   Quote lukesvette Quote  Post ReplyReply Direct Link To This Post Posted: August 09 2010 at 3:29am
Nothing further I can add here but wanted to say "what's up Alan!!!!"
welcome back!!
Paul
Veteran of Operation Iraqi Freedeom
101st Airborne(AirAssault!)
God Bless America
Support Our Troops
Back to Top
Forum Jump Forum Permissions View Drop Down
Bulletin Board Software by Web Wiz Forums® version 9.68
Copyright ©2001-2010 Web Wiz
This page was generated in 0.859 seconds.
Official C3 Vette Registry Community:
Home | Forums | Email | Who's Online | Clubs | Events | Member Stats
Other Official C3 Vette Registry Areas:
Members | Research | Shop | My Account | About C3VR
Corvette is a registered trademark of the General Motors Corporation(GM) & Chevrolet Motor Division. Vette Registries, LLC is responsible for all site content (except where otherwise noted) and does not claim or imply that Chevrolet or GM is responsible for Official C3 Vette Registry content. Vette Registries, LLC is independent from GM and is not affiliated with, sponsored or supported by GM.  Copyright/trademark/sales mark infringements are not intended, or implied and are in fact used to support GM, Chevrolet and Corvette
Official C3 Vette Registry content is Copyright 2001-2010, Vette Registries, LLC. Content may not be reused without written consent. All Rights Reserved. NS
Corvette (Vette) Model Years on this site: 1968 1969 1970 1971 1972 1973 1974 1975 1976 1977 1978 1979 1980 1981 1982 60
